Postado originalmente por
TOLENTINO
O manual técnico e de serviço da Versys 1000, traz a seguinte informação sobre lubrificação da corrente.
Final Drive
Drive Chain Lubrication Condition Inspection
If a special lubricant is not available, a heavy oil such as
SAE 90 is preferred to a lighter oil because it will stay on
the chain longer and provide better lubrication. •If the chain appears especially dirty, clean it before lubrication.
NOTICE
The O-rings between the side plates seal in the lubricant
between the pin and the bushing. To avoid
damaging the O-rings and resultant loss of lubricant,
observe the following rules.
Use only kerosene or diesel oil for cleaning of the O
-ring of the drive chain. Any other cleaning solution
such as gasoline or trichloroethylene will cause deterioration
and swelling of the O-ring. Immediately
blow the chain dry with compressed air after cleaning.
Complete cleaning and drying the chain within
10 minutes.
