[Lançamento] Nova Ducatti Mustistrada - Versão de Impressão +- BMW GS Brasil (https://www.bmwgsbrasil.com.br) +-- Fórum: Motos em geral (https://www.bmwgsbrasil.com.br/Forum-motos-em-geral) +--- Fórum: Discussão Geral (https://www.bmwgsbrasil.com.br/Forum-discuss%C3%A3o-geral) +---- Fórum: Outras Motos - Discussão Geral (https://www.bmwgsbrasil.com.br/Forum-outras-motos-discuss%C3%A3o-geral) +---- Tópico: [Lançamento] Nova Ducatti Mustistrada (/Thread-lan%C3%A7amento-nova-ducatti-mustistrada) |
[Lançamento] Nova Ducatti Mustistrada - shw - 04-11-2014 Ducati’s big-selling Multistrada 1200 gets a massive overhaul for 2015, making it an almost all-new bike, with variable valve control engine, all-new electronics, revised styling and improvements to rider comfort and convenience. There are two models – the standard 1200, and an ‘S’ model which also includes the D-Air version that links to Dainese’s electronically-controlled rider airbag system. ![]() The overall appearance of the new bike is still very recognisably Multistrada, but the new Ducati Variable Timing (DVT) version of the Testastretta 1198cc V-twin is now producing 160bhp at peak power, and with gains throughout the range thanks to the engine’s ability to adjust the valve timing to suit both low rev torque and higher rev power. ![]() Variable benefits Ducati revealed they would be using the DVT system on a secret new 2015 bike three weeks ago, and MCN spy shots confirmed two weeks ago that it would be the Multistrada 1200. The system works to independently vary the timing of the camshaft that control both intake and exhaust valves according the best solution determined by the revs. The intention is to provide the best of both worlds with low to medium rev torque and engine smoothness but higher rev power and performance. It works to constantly vary the degree of valve overlap so it’s always optimally matched to engine revs. The DVT system is divided into two parts: an external housing rigidly connected to the timing belt and an internal mechanism connected to the camshaft. The internal mechanism can rotate and advance or retard the valve timing depending on the oil pressure in control chambers, which is adjusted by dedicated valves according to the engine revs and load. New electronics The IMU is the control and monitoring unit that processes and governs all the other electronic systems, including the traction control, anti-wheelie, cornering ABS, cornering lights and the four riding modes along with the Skyhook semi-active suspension. The riding modes are carried over from the outgoing model with Sport, Touring, Urban and Enduro modes. They range from offering the full 160bhp in Sport and Touring but drop to 100bhp in the other modes. ABS, traction control, the semi-active suspension, ride height, throttle response and wheelie control are all adjusted according to each mode. Rider comforts A larger front fairing, bigger (adjustable) windscreen, altered riding position and re-profiled height adjustable seat are, Ducati claims, big contributions to the improvement of rider comfort on the new Multistrada 1200. The seat now adjusts between 825mm and 845mm and the handlebars are rubber mounted to reduce vibration. The 12v power sockets have also been moved to more convenient locations. UK on the road prices: Multistrada 1200 £12,995 Multistrada 1200S red £15,595 Multistrada 1200S white £15,795 [Lançamento] Nova Ducatti Mustistrada - Dan Chris - 10-11-2014 Meu Deus ... que sonho essa maquina ... linda demais e tecnologia de ponta ... alguem sabe quando vem ao Brasil??? [Lançamento] Nova Ducatti Mustistrada - RicBoris - 10-11-2014 Linda demaissss!!!! [Lançamento] Nova Ducatti Mustistrada - Corbelli - 17-11-2014 Provavel que no BR somente no 2 semestre de 2015 visto que hoje é produzida via CKD [Lançamento] Nova Ducatti Mustistrada - sal silva - 17-11-2014 Tem Air Bag é?Essa Italiana não é fraca,fico aqui como Italo brasileiro devaneando nos campos das possibilidades rsrs [Lançamento] Nova Ducatti Mustistrada - Iceman - 17-11-2014 O Air-Bag é da Dainese, A Ducati apenas oferece a interface eletrônica para o sistema da Dainese. [Lançamento] Nova Ducatti Mustistrada - sal silva - 17-11-2014 [quote=Iceman]O Air-Bag é da Dainese, A Ducati apenas oferece a interface eletrônica para o sistema da Dainese.[/QUOTE Aé? Pelo menos a Ducati oferece esse tal de interface rsrsrs. |
